TDCI seatbox into TD5/300tdi 110?
Hi All
Had a search and couldn't find a definite answer on this.
I've been offered a good condition TDCI seatbox to use on my 110 rebuild (which is being built as a ROW spec 300tdi ie all TD5 spec bits/wiring/dash etc), should fit fine but I'm just wondering about the tunnel mounting, is the mount area the same ie will a R380 tunnel bolt straight onto it or am I better off looking for a good TD5 seatbox?
If I go for the TDCI one are there any other changes that I need to make before I get it painted?
Cheers
Ben
