Kaliboy Posted June 12, 2015 Share Posted June 12, 2015 Hey guys, Just fitted some 265 75 16 MTs, on Boost Alloys to my Discovery. I've adjusted the steering stop locks by 5mm, thinking this would give a decent enough clearance of the arms, but when I've test driven it the bolts are just too far forward now. Can anyone tell me the best measurement for adjustment? I measured them at 26mm before I fiddled with them and 30mm after. Also, is there supposed to be a locking nut on them? Mine only has a washer and standard nut. Cheers in advance. Matt Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted June 13, 2015 Share Posted June 13, 2015 Jack it. Put the front axle on stands. Swing the wheels fully left and adjust the rh bolt. And visa versa. ... The bolt should just have a skinny nut to lock it. Quote Link to comment Share on other sites More sharing options...
Kaliboy Posted June 13, 2015 Author Share Posted June 13, 2015 Cheers Ron. Just read that the recommended distance is 20mm from the radius arms. That's where I've gone wrong. I've over adjusted on the front and the bolts are passing the flange. Quote Link to comment Share on other sites More sharing options...
