DefenderJay Posted January 18, 2016 Share Posted January 18, 2016 Hi. My headlights have stopped working on my 1993 defender. It has the dim dip system. Push the stalk forward one with the ignition on and the side lights and headlights glow as it should. Push forward on the stalk again and the headlights go out, small sidelights stay on. Checked all fuses, bulbs work as they light up with the headlights, relay clicks in both positions. Any ideas as to the problem. Thanks in advance. Jay Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 18, 2016 Share Posted January 18, 2016 Your main lighting switch had melted and requires replacement. A common fault as the headlight current is run through the switch rather than relays. HTH Mo Quote Link to comment Share on other sites More sharing options...
DefenderJay Posted January 18, 2016 Author Share Posted January 18, 2016 Head light switch is fine. Relay clicks. Quote Link to comment Share on other sites More sharing options...
