nige90 Posted November 22, 2006 Share Posted November 22, 2006 Feels like the clutch on the 90's about to give up the ghost. Pedal travel is reducing (goes solid half way down as the slave tops out) and there's a horrid shrieking from the bellhousing when depressed. Now have to knock the engine off to engage reverse (all in 20 miles too) I have to admit to being a little......p****d at this as the clutch was new 18 months ago when I fitted the 200Tdi. I've had the box of a few years back when it popped a selector, and the engine the aforementioned 18mths ago but never both together. I've decided to make the most of the situation and replace the output gear in the box and put new mains, big ends and rings/pistons in the motor. So is it any easier to remove them as one huge lump and does this negate the need to remove the floor pans and interior panels ? BTW it's an '87 90 with LT77 and 200Tdi. Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted November 22, 2006 Share Posted November 22, 2006 Nige, Ive never done it on a 90 (on series and Rangies though), to me, any access you can gain is a bonus, I wouldnt think twice about taking out floor panels for more access. If your working on both, then I personaly would go for them together, assuming your crane/hoist is man enough, the more front panels you can remove will make it easier and easier. Also, take the opportunity to re-loom / brake pipe if you need them, so much easier with an empty bay IMHO. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 22, 2006 Share Posted November 22, 2006 2 separate problems IMHO The first (solid pedal) is probably the ball heading south through the clutch fork, the second one sounds like the release bearing. Did you change both these when you did it 18 months ago? Quote Link to comment Share on other sites More sharing options...
nige90 Posted November 22, 2006 Author Share Posted November 22, 2006 2 separate problems IMHOThe first (solid pedal) is probably the ball heading south through the clutch fork, the second one sounds like the release bearing. Did you change both these when you did it 18 months ago? Yep, sure did and that's what makes it so bloody annoying. Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted November 23, 2006 Share Posted November 23, 2006 Yep, sure did and that's what makes it so bloody annoying. IIRC Rakeway are producing a aluminium/steel thrust bearing to help resove this. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted November 23, 2006 Share Posted November 23, 2006 IIRC Rakeway are producing a aluminium/steel thrust bearing to help resove this. and Hensonway do a rather neat reinforced fork! Quote Link to comment Share on other sites More sharing options...
