Daymo Posted April 21, 2016 Share Posted April 21, 2016 I have had a flickering oil pressure light and so replaced the sender which didn't cure it. I have now taken the inspection cover off to see if the camshaft bearing hs moved, but I'm not sure what it should look like. I've attached a picture. Could someone please have a look and advise me. Thanks Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted April 21, 2016 Share Posted April 21, 2016 can you push pull it backwards and forwards? We found the bolt that holds the timing gear to the cam repeatedly came loose. Not ideal, but you need to take off the timing case and have a look! Quote Link to comment Share on other sites More sharing options...
Daymo Posted April 21, 2016 Author Share Posted April 21, 2016 I can't move it at all. Quote Link to comment Share on other sites More sharing options...
