madmatt Posted May 11, 2016 Share Posted May 11, 2016 Please could some one help with some or all of the following numbers please All are for a 1996 300tdi 130 Clutch kit including the fork etc Slave cylinder Master cylinder clutch Rear crank oil seal Power steering pipes The plastic inserts in front wing that lights screw into The smaller rear helper springs that fit down middle of other rear springs Also does anyone know the numbers of the newer clips for fuel/brakepipes that fit the later chassis as per what Marsland supply. Also if anyone has any experiance if owt else that would make sense to change or would make life easier then please let me know. Many Thanks Matt Quote Link to comment Share on other sites More sharing options...
