300tdi braking problem
  • Please log in to reply
5 replies to this topic
#1 breezecloe
breezecloe
    Newbie
  • New Faces
  • Pip
  • 4 posts
Posted 30 June 2007 - 05:41 PM
Hi
When we apply the brakes on our discovery there is a loud hissing/whooshing type noise which sounds like its coming from the brake pedal itself. Also the brakes are not working very well now either. Does anyone have any ideas please? Im thinking servo, vacumn pump?
Thanks
#2 BogMonster
BogMonster
    Old Hand
  • Moderators
  • 12,153 posts
  • Location:Third rock from the Antarctic - 5141.8'S 5750.5'W
Posted 30 June 2007 - 07:17 PM
internal leak in the servo would be my guess if it only happens when you press the pedal down, if it is whooshing all the time it could be the pump
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Mitsubishi Shogun SG2
#3 breezecloe
breezecloe
    Newbie
  • New Faces
  • Pip
  • 4 posts
Posted 30 June 2007 - 11:28 PM
It only happens when you depress the pedal, how can i test for an internal leak? or should i just go and buy a new servo?
Thanks
#4 BogMonster
BogMonster
    Old Hand
  • Moderators
  • 12,153 posts
Posted 01 July 2007 - 02:09 PM
Thanks
The difference is if everything is ok it should be a gentle squish like a cowpat between your toes, if it sounds like you have just slashed a tyre it will mean there is a problem :)
The servos are sealed units I think, so there is not really any way of proving the cause of the problem without sawing a hole in it to see if the diaphragm is split, and after that you will need a new one anyway...
#5 JimAttrill
JimAttrill
    So important that they banned 50 000 IP addresses to shut me up
  • Settled In
  • PipPipPip
  • 2,909 posts
  • Location:S 2601.3' E02758.5 1373m Johannesburg, South Africa
Posted 01 July 2007 - 06:10 PM
Push on the pedal, start the engine. If pedal goes towards the floor, the servo is ok. If pedal stays where it is, it is stuffed.
1996 Defender 300Tdi 110 csw
#6 breezecloe
breezecloe
    Newbie
  • New Faces
  • Pip
  • 4 posts
Posted 01 July 2007 - 08:40 PM
Thanks,will give a try.
