666dawn Posted August 4, 2013 Share Posted August 4, 2013 ok people start from cold, engine fires up first time but a plume of blue smoke emits from the exhaust for a couple of seconds then clears.. ive been told leaking injectors any other ideas what about changing the glow plugs could one or two be damaged, and is it easy enough job for me to change the glow plugs or is it a garage job.... Quote Link to comment Share on other sites More sharing options...
EggNChips Posted August 5, 2013 Share Posted August 5, 2013 You don't say what engine it is, so I'm guessing it's a TD4. Blue smoke is oil, if it's only on start up then it's likely to be valve guide seals. If it's a leaking injector, it would be white/grey smke that smells like a BBQ. Quote Link to comment Share on other sites More sharing options...
666dawn Posted August 5, 2013 Author Share Posted August 5, 2013 thanks for that it is a td4 so i take it i need to take to the garage Quote Link to comment Share on other sites More sharing options...
EggNChips Posted August 5, 2013 Share Posted August 5, 2013 Depends how bad it is and whether you can live with it. Slightly leaking valve guide seals and / or leaking injector will not in itself cause further damage (as long as you keep an eye on oil levels). Causes a bit of smoke at start up, but that's it. Quote Link to comment Share on other sites More sharing options...
EggNChips Posted August 5, 2013 Share Posted August 5, 2013 p.s. the glow plugs will not really make any difference to a TD4 in this weather. Quote Link to comment Share on other sites More sharing options...
666dawn Posted August 5, 2013 Author Share Posted August 5, 2013 thanks again ill see how it go,s Quote Link to comment Share on other sites More sharing options...
666dawn Posted August 5, 2013 Author Share Posted August 5, 2013 took 2 attempts to start today this morning and when i finished work been stood 9 hours at work i suppose you could call that a cold start two attempts may not sound to excessive but it usually starts first time .... Quote Link to comment Share on other sites More sharing options...
EggNChips Posted August 6, 2013 Share Posted August 6, 2013 Another though would be the crankcase filter. Is it definitely blue smoke and not white/grey? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 6, 2013 Share Posted August 6, 2013 I was about to suggest crank filter or a dodgy EGR as other sources of oil/crud in the intake. TD4's are pretty solid so it's surprising if it's a genuine mechanical fault, and I'd want to rule out as much easy/cheap stuff as possible before tearing the engine apart. I find if mine gets lazy in winter or with other faults (poor glow plugs, failing fuel pump, etc.) and takes more than a quick crank to start it will cough a big cloud of smoke out of the back but then run fine. Quote Link to comment Share on other sites More sharing options...
stebbo47 Posted August 9, 2013 Share Posted August 9, 2013 Would agree about crankcase filter, similar problem with my TD4 but with blue smoke after any length of idling as well.Changed filter and no more blue smoke. The filter was rock hard and appeared to not have been changed for years if ever! Quote Link to comment Share on other sites More sharing options...
