Peterneilbilly Posted July 4, 2016 Share Posted July 4, 2016 My rear washers don't have water getting to them yet I can hear the pump running any ideas please Quote Link to comment Share on other sites More sharing options...
Shackleton Posted July 4, 2016 Share Posted July 4, 2016 If it's a Discovery 2 you need to take the rear door car off. Behind it once you trace the washer pipe you'll find a tiny inline valve in it. This is the one way valve that stops the water running back down the pipe when not in use - it's just there to make sure the water comes out of the washer instantaneously when you press the button. They go bad and stop the water altogether. I wasn't bothered ordering a new one so took a small drill bit and drilled through the valve and replaced the body in the pipe. Hope that helps. George Quote Link to comment Share on other sites More sharing options...
SPendrey Posted July 7, 2016 Share Posted July 7, 2016 ...or, as in my Disco 1, the pipe and jet at the rear pillar just parted company somehow. Every time I pushed the "wash" button, the water just filled the rear quarter until it found one of the many holes to fall out of! Quote Link to comment Share on other sites More sharing options...
