woff Posted March 31, 2008 Share Posted March 31, 2008 I've done some serious searching around on the many posts on LR4x4 and seen this thread http://forums.lr4x4.com/index.php?showtopi...3&st=0& and I've got a slight issue with finding parts. No one so far admits to having parts. Has any one recently been able to find parts? If so where? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 1, 2008 Share Posted April 1, 2008 What injector pump is it? I have a few here that I can take bits off. Les. Quote Link to comment Share on other sites More sharing options...
woff Posted April 1, 2008 Author Share Posted April 1, 2008 Well they are both off Bosch 347's. With LR No. ERR0459 Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 2, 2008 Share Posted April 2, 2008 Sorry - what engine? Les. Quote Link to comment Share on other sites More sharing options...
woff Posted April 2, 2008 Author Share Posted April 2, 2008 200 TDI - my fault lac of info. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 2, 2008 Share Posted April 2, 2008 Can't help in that case - sorry. I only have TD, N/A, and series pumps. This type of repair can be done in situ by a diesel specialist and is generally less than £100. Les. Quote Link to comment Share on other sites More sharing options...
Mikeba53 Posted April 3, 2008 Share Posted April 3, 2008 Try a new O Ring on the Spindle of the injector pump I had the same problem and thats whot it was its OK now, I got the part that you are after from Pander Fuel Injection but did not need it, you will have a job getting one as most places want you to send the Pump to them so thay can do the job, there AD is belowe Pander Fuel Injection 4a Bridge Industries Fareham Hampshire PO16 8SX Tel: 01329-220551 Below is what I found on how to replace the O Ring thanks to CharlesY Mike Re: throttle spindle seal on the Tdi Injection pump is leaking ________________________________________ Here is what I wrote for the other leaking pump spindle: I fitted a new O-Ring to my NA pump myself. It isn't difficult, but it needs a lot of care. The whole innards of the pump are under a little pressure from the fuel lift pump so it does leak steadily when the O-ring goes. Wash the pump VERY CLEAN ..... it must be utterly crud free! As I recall, the trick is to get the throttle lever off the spindle first, and this needs to be done WITHOUT disturbing the settings of the multi-part lever. Then it is possible to undo the screws holding down the top cover, and as you lift the lid up, you can feed the throttle spindle down VERY CAREFULLY. Common sense will tell you what all bits you need to undo the get the pump lid clean off the body of the pump. The two levers (Throttle and tickover) are connected to springs , so you need to be careful! Once the lid is off, the o-ring is perfectly accessible, and can be replaced with one from any 0-ring kit. Then you head back to the pump, hook on the springs, feed the spindle back up the hole and carefully through the new o-ring, and screw the lid down neatly onto its rubber seating gasket. Bleed it ... job done. Cost 1p for an o-ring, and maybe an hour or two if you take plenty time. Saving .... hundreds of pounds probably. If you were anywhere near here I would do it for you if you whip the pump off, but really, taking the pump off is NOT required, if you know how to be careful. NO hammers are needed for this job, so that rules out most conventional LandRover repairs experts and methods! CharlesY Quote Link to comment Share on other sites More sharing options...
woff Posted April 4, 2008 Author Share Posted April 4, 2008 Cheers Mike, I'll have a go later. Rgds, Quote Link to comment Share on other sites More sharing options...
