henk Posted October 19, 2008 Share Posted October 19, 2008 How do I enter the injector codes with the Nanocom in stand-alone mode ? Example: Injector 1 code is NMLEH I can choose first 2 letters NM and select Then choose LE and select but then I get for 3rd pair something like 3H or so, the 5th letter appears but preceeded by a number Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted October 19, 2008 Share Posted October 19, 2008 The Nanocom user manual isn't very helpful. This is from the Rovacom Lite help: "Please be aware that the value you read with the Vehicle Server and then display is the actual numerical value which is stored in the ECU. To translate the Alpha code value into the correct numerical value the following conversion can be used: For scheme 1 (earlier - the early ECU would not store a value higher then 3) A = 0 or 3 B = 1 C = 2 It should be noted that with the Rovacom Lite/Pro unit it is possible to enter a value of 3 in the fifth position. Whilst this is possible other test equipment will not be able to accept this and in this case the character A will be displayed. For scheme 2 (later) E = 1 F = 2 G = 3 H = 4 J = 5 K = 6 L = 7 M = 8 or 0 " What's printed on the injector and what's inside the ECU are the same but different, so to speak Quote Link to comment Share on other sites More sharing options...
