Muddylandy Posted March 9, 2009 Share Posted March 9, 2009 Hi Guys went to look my landy and the key kept turning and then the lock cylinder came out with the key. Is it just a clip which holds the lock in place or do I need to and goi and buy more bits. Cheers Mark Quote Link to comment Share on other sites More sharing options...
SacredDog Posted March 9, 2009 Share Posted March 9, 2009 Hi Guys went to look my landy and the key kept turning and then the lock cylinder came out with the key. Is it just a clip which holds the lock in place or do I need to and goi and buy more bits. Cheers Mark If my memory serves me correctly there is a small screw that retains the lever that operates the lock, when that is undone the barrel comes out with the key. I'll see if I can find some pictures for you. Colin. Quote Link to comment Share on other sites More sharing options...
Muddylandy Posted March 9, 2009 Author Share Posted March 9, 2009 If my memory serves me correctly there is a small screw that retains the lever that operates the lock, when that is undone the barrel comes out with the key.I'll see if I can find some pictures for you. Colin. many thanks colin Quote Link to comment Share on other sites More sharing options...
SacredDog Posted March 9, 2009 Share Posted March 9, 2009 many thanks colin OK, finally found it, it's dead centre of the attached picture. If your are lucky the screw is still in position or amongst all the rubbish that collects in the bottom of the door, if you look at the back of the barrel you will get an idea of what thread size you are looking for, I think the screw is about 10mm long. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted March 9, 2009 Share Posted March 9, 2009 To get to the screw, you have to either take apart the inner frame of the door or.... http://forums.lr4x4.com/index.php?s=&s...st&p=311711 The second picture in that post, you can see I've drilled a small hole in the inner frame to allow me to remove/replace the screw in question without major dissasembly. Quote Link to comment Share on other sites More sharing options...
SacredDog Posted March 9, 2009 Share Posted March 9, 2009 To get to the screw, you have to either take apart the inner frame of the door or....http://forums.lr4x4.com/index.php?s=&s...st&p=311711 The second picture in that post, you can see I've drilled a small hole in the inner frame to allow me to remove/replace the screw in question without major dissasembly. So the small access hole (about an Inch square) I had in mine wasn't standard then? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted March 9, 2009 Share Posted March 9, 2009 Hmm, might have been. I dunno, I can only pass judgement on my doors. There may well be an access hole in other versions, if so then all the better. Quote Link to comment Share on other sites More sharing options...
SacredDog Posted March 9, 2009 Share Posted March 9, 2009 Hmm, might have been. I dunno, I can only pass judgement on my doors.There may well be an access hole in other versions, if so then all the better. The access hole was in my '89 110 Hicap, from memory it looked original or perhaps had just been done well a long time ago. Looking at your picture I think it almost filled that little corner where your hole is, just a square hole with rounded corners. I will have to have a look at my '94 130 doors next time I have the door cards off, when I did the lock barrel on that one I took the whole of the panel out to sort out a sticky window winder at the same time, so I didn't take much notice. If it's not there I will do the same as you have. Colin. Quote Link to comment Share on other sites More sharing options...
