mudmagnet Posted March 3, 2011 Share Posted March 3, 2011 my rear windows on my disco wont work, ive tried replacing switches replacing relays and even followed a link i found on here about removing the window ecu but nothing works, my question is can i wire the rear windows up on there own through a new relay and new switches without using any existing components except of course the window motors Quote Link to comment Share on other sites More sharing options...
Niamh Posted March 3, 2011 Share Posted March 3, 2011 You think you've got problems... mine don't work when everything's neatly assembled, but with everything 1/2 re assembled they do! Niamh Quote Link to comment Share on other sites More sharing options...
ches Posted March 3, 2011 Share Posted March 3, 2011 have a look here. seems to be a common problem. http://www.landyworld.co.uk/discowindows.htm Quote Link to comment Share on other sites More sharing options...
leon_81 Posted March 4, 2011 Share Posted March 4, 2011 I had the same issue when I got my 300tdi - it was a dodgy bit of solder in the window ecu - I followed a guide online and resoldered, all been ok for nearly a year now Quote Link to comment Share on other sites More sharing options...
lawrence Posted March 4, 2011 Share Posted March 4, 2011 would this work for a front window or is it only the rears, reason for asking is my front passanger window does not work but my rear one's are fine. Quote Link to comment Share on other sites More sharing options...
leon_81 Posted March 7, 2011 Share Posted March 7, 2011 Try another switch - one of mine is a bit didgy and works when it wants Quote Link to comment Share on other sites More sharing options...
lawrence Posted March 7, 2011 Share Posted March 7, 2011 I swapped the switche over in the centre console for the one in the rear that works but still no joy. Could it be the motor and if so is it possible to swap the front and rear ones over. Don't use the back seats so no need for the window to work. Quote Link to comment Share on other sites More sharing options...
Bobbin Posted July 3, 2011 Share Posted July 3, 2011 Bingo,sorted.Very happy children now in back seats. Quote Link to comment Share on other sites More sharing options...
