tweetyduck Posted April 10, 2012 Share Posted April 10, 2012 my rear airlift has broken so i'm in the dealer in mbeya, tanzania... I want to either fixt the airlift which is possible or fit rear helpers to my 110. I prefer the helpers. I have red red on the rear both side. These should really be red green for the standard inner helper setup. Question is whats the diff between red red and red green. i think it will work fine but i cannot get to the spring table to just satisfy myself it will be fine. Can't see why it won't. Comment welcomed. I'm doing this from the dealer on my phone so bear with me. Quote Link to comment Share on other sites More sharing options...
Diff Posted April 10, 2012 Share Posted April 10, 2012 Hope the trip is going well. The red red 110 rears are 12mm longer in the free length than the red green 110 rears. Same poundage at 330 lbs per inch. Hope this helps, Regards, Diff. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted April 10, 2012 Author Share Posted April 10, 2012 thanks thats what i needed to know. I'm running just under 3000kg and its even between front and rear iirc. I can't find my figures for the exact front rear split. What i do know is without the helpers the rear is low. Quote Link to comment Share on other sites More sharing options...
Diff Posted April 10, 2012 Share Posted April 10, 2012 From memory, I am pretty sure the helpers are about 90 lbs per inch, so you'll have around 420 lbs. Regards, Diff. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted April 10, 2012 Author Share Posted April 10, 2012 so i'm 216 quid lighter and have a newish set of helper springs and mounts. The garage nicked em off a puma with 25,000km on the clock with a broke engine. At the same time my anti roll bar uj's were noted to be in bad shape. We made some new rubber bushes from my spare suspension rubbers using a dremmel and grinder.to shape them and fitted new gaitors and grease. Good as new.... Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted April 24, 2012 Author Share Posted April 24, 2012 met a overland rental company that run defenders, discos and series for cape town to nairobi. Seems all airlift 1000 kits fitted to defenders fail the same way. They fit them to all their cars and they all fail the same. The discos last ages but the defenders last no time just like mine. So there you have it. Steer clear of them. O saw 3 of his cars all failing the same way as mine. He replaces the moints with machines aluminium as i was going to do but i couldn't find ali in the right size in tanzania. Airlift are oficially rubbish, period. Quote Link to comment Share on other sites More sharing options...
Guest Posted April 24, 2012 Share Posted April 24, 2012 Now you tell me Neil, I brought some on your recommendations!!! I guess I need to either write to Airlift and get some replacement tops or get some machined. Jason. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted April 25, 2012 Author Share Posted April 25, 2012 all i can do is apologise. Obviously driving around here takes its toll on the top mounts. Making some from wood or ali was my choice. The bags were fine. I ran mine at 20 and 25psi and the guy here at 15 and the tops all went exactly the same way. Theres some photos if you want them and i think some on my blog. He dis say the discos never go, only defenders and he's running loads of cars' even series. He did say if a bag goes you cannot fix it so i gave him mine. Face the ali with rubber to protect the bag and they last ages he says.ali bar in the diameter needed will be expensive so i'd contact airlif for their lifetime warantee, and see what they say. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted April 25, 2012 Author Share Posted April 25, 2012 btw....if you need the photos for airlift just let me know. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted June 17, 2012 Author Share Posted June 17, 2012 I can now confirm after doing a bit of Google and mainly just so Jason can rest easy. Airlift have redesigned the top mounts http://www.airsprings.cc/4x4/Airlift/AL1000/LAN02.MN285.738.pdf take a look. They have now included a steel ring to stop the problem we all seemed to have. I would have thought theres a good case to give them a call and get some. However since these are also a Britpart item should you go to Britpart ??? My bags were donated to some passing mechanic with a fleet of Defenders so i won;t be making a claim for new mounts. Sorry about this Jason but at least theres now a fix. They did work great when they weren't broken !!! Quote Link to comment Share on other sites More sharing options...
Guest Posted June 17, 2012 Share Posted June 17, 2012 Cheers Neil, Thanks for finding that I have the older version well mine are 9 months old now, and have just fitted another set to someone's truck a couple of weeks ago that were the same so I guess Britpart have lots of the old design on the shelf, I bet it will be a case that they will want them to fail first, however given that yours went a few miles into your trip I will take the risk for now. Glad you are having a good trip, I am surprised you didn't just get the 1/2 shafts welded to stop the clunk that's the bush mechanics way of fixing them!! Glad Matilda and dash are doing well and you are still enjoying things. Jason. Quote Link to comment Share on other sites More sharing options...
Guest Posted August 31, 2012 Share Posted August 31, 2012 Well one of mine failed whist away on holiday, I have just email Air Lift to see what they say as Britpart are still selling the old type. Jason. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted September 1, 2012 Author Share Posted September 1, 2012 Let us know how you get on and please if needed quote what I have said. They actually owe me for a new set but i'm not about to carry carp around with me for the rest of the trip to make the claim. Lets see how good the american customer service is. Yours lasted about the same as mine all told. (Again Sorry ) Quote Link to comment Share on other sites More sharing options...
Guest Posted September 3, 2012 Share Posted September 3, 2012 Well I haven't heard anything yet but it was the weekend.... Here is a photo of my failed unit. Uploaded with ImageShack.us Jason. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted September 3, 2012 Author Share Posted September 3, 2012 That would be exaclty how they all fail (accrding to the guy that runs the rentals) and as mine did. Also exactly whay they redesigned the mount. So you're on a winner. They do have a lifetime guarantee so they should sort it. The Britpart thing also messes it up but they also offer a lifetime guarantee do they not on ALL products?? Regards from the end of a continent. (At least we will be in a few days. One continent completed and a few to go !) Quote Link to comment Share on other sites More sharing options...
Guest Posted September 3, 2012 Share Posted September 3, 2012 Cheers Neil we will have to see what they say. Surely you have finished two continents now, Europe and Africa!! I'm still reading your blog with great envy, Best regards to the four of you. Jason. Quote Link to comment Share on other sites More sharing options...
Guest Posted September 6, 2012 Share Posted September 6, 2012 Just received a classic email from them telling me I fitted it incorrectly as the protector was above the spring mount!! Oh and apparently they have not modified the kit. I sent him the link back that Neil posted above and pointed out that it's like that because it's split. Jason Quote Link to comment Share on other sites More sharing options...
Ex Member Posted September 6, 2012 Share Posted September 6, 2012 I wonder if the new spacer is NOT made by Airlift but by Airsprings.cc? Quote Link to comment Share on other sites More sharing options...
Ex Member Posted September 6, 2012 Share Posted September 6, 2012 This is the correct manual straight from Airlift... http://www.airliftcompany.com/manuals/MN-285.pdf Quote Link to comment Share on other sites More sharing options...
Guest Posted September 6, 2012 Share Posted September 6, 2012 I wonder if the new spacer is NOT made by Airlift but by Airsprings.cc? I think they are the same company. This is the correct manual straight from Airlift... http://www.airliftcompany.com/manuals/MN-285.pdf That was the old one this the new one wit the modified spacer http://www.airsprings.cc/4x4/Airlift/AL1000/LAN02.MN285.738.pdf Jason Quote Link to comment Share on other sites More sharing options...
Guest Posted September 17, 2012 Share Posted September 17, 2012 OK, so I now have some clarification and understanding around these things, the PDF that Neil originally attached was from Gremeltech, it was there response to an issue with the Airlift 1000 Gremeltech charge 960 rand for the modified kit plus shipping to the UK however they recommend that I didn't buy the kit from them and just welded the bar across the rear turrets. The response from Gremeltech has been great and considering that they didn't sell me the kit in the first place, and didn't even want to sell me the modified kit, they were very quick in responding and helping me out. After a bit of back and forth via email with Airlift, they have despatched a new set of spacers to me via Fedex which should be with me later in the week. So it looks like I will have to weld the bars onto the turrets when I get the replacement spacers although I may look to see if there is another way of stopping the spacer coming through the turret first. Jason. GRA61724C0.Rear Land Rover Defender 110 All .pdf Quote Link to comment Share on other sites More sharing options...
Guest Posted September 18, 2012 Share Posted September 18, 2012 So true to their word the replacement spacers arrived today, replaced on photo evidence at no cost good service from airlift, just got to modify them now. Jason Quote Link to comment Share on other sites More sharing options...
