GL88 Posted October 5, 2013 Share Posted October 5, 2013 Getting a bit of the wrong sort of noise from under the bonnet and there seems to be a small amount of ally dust on the exhaust side of the engine. On further investigation the likely culprit is the idler pulley for the serpentine belt - it wobbles and the yellow seal is floating around loose at the back! Non- air con engine so there are two idlers and it is the one on the left as you face the engine (nearer the engine of the two above the PAS pump). I think I've got as far as working out that each of the two idlers has a different part number (ERR6493 and ERR6658) but can't find which it is that I need. And while I'm asking, are the spring retainers available for the quick release screws that retain the fan shroud? One has disintegrated and the other three will soon follow it. Thanks in anticipation. Quote Link to comment Share on other sites More sharing options...
western Posted October 5, 2013 Share Posted October 5, 2013 drive belt & idler in http://lrcat.com/31/4/53210 & http://lrcat.com/31/4/53211 Quote Link to comment Share on other sites More sharing options...
GL88 Posted October 6, 2013 Author Share Posted October 6, 2013 Thanks. Just what I need. Now I just need to find someone who will supply a Genuine Part rather than an unsatisfactory one. Quote Link to comment Share on other sites More sharing options...
western Posted October 6, 2013 Share Posted October 6, 2013 try Brit-car http://www.brit-car.co.uk/ tell them you want a geuine LR part not a pattern. Quote Link to comment Share on other sites More sharing options...
