grinding sounds from 14 month old tbox
Replaced the lt230 on my 90 14 months ago. .. and today got a horrible grinding noise under power.... diminishes on the over run.... and goes totally with main box is nuetral coasting downhill....
I suspect the idler gear in the tbox has done a bearing.....
Any Other ideas?...
Not found any unexpected slack in the diffs yet.... got it on 4 axle stands running in gear but as there's no load i can't hear it
