Blanco Posted May 11, 2017 Share Posted May 11, 2017 Looking for the correct O-ring for this steel water pipe, please. RR P38 2.5 DHSE, runs from the front of the block where it is retained bt a bolt, just by the w/puimp and just under the top hose housing also bolted to the block, can be seen here as a black pipe behind the shinier EGR pipe.. It turns through 180 deg and then runs backwards (Drivers side) along the top of the exhaust manifold and joins a tee into what look to be heater pipes . Just taken out a yellow one that is so damaged I have no chance of measuring it. Thanks Rob I need to sort Microcat if I can, but many of the stickies here seem broken, and I need a clear head I think to embark on what sounds a bit of a fiddle Quote Link to comment Share on other sites More sharing options...
