Josh999 Posted July 4, 2017 Share Posted July 4, 2017 Hi guys, I have a lovely knocking and clunking sound on my 200tdi 1993 90. Brand new props and UJ's, however there's lots of play in both... (diff or transfer?). When I pull away it will clunk, if I'm driving and come off the accelerator it will sound like a bag of nails. I think it will be easier and cheaper to buy a v8 disco, swap both axles (rear discs is a bonus) and I nice v8 to finish it off. Will a disco2 take much modification for the axles? Or shall I stick with a d1? Unless someone can spot what the hell is going on underneath? Don't think it's a Aframe joint. Thanks for reading, and any help at all is taken greatly!! Quote Link to comment Share on other sites More sharing options...
landroversforever Posted July 4, 2017 Share Posted July 4, 2017 D2 axles are totally different - wider and different bracketry. I think you're better off fixing the faults in what you've got. Reasonable diffs aren't expsnsive, same goes for the transferbox. Get under it and give it all a wiggle with a pry bar, you'll soon see what's not right. Quote Link to comment Share on other sites More sharing options...
