TDV 6 Injector test
Hercu
The Disco is up and alive and the knocking sound was a hydraulic lifter and replaced all on the one bank
Now the disco is over fueling madly and had the Injectors tested but with my limited knowledge I do not know what the report says
Must I replace only no 1 Injector/ is that the problem ?
The other 5 seems to have passed all tests.... is it Good...OK...Fair or Bad and on the border line ???
CRB_282018_1113_31454 NO_ 1.pdf
CRB_282018_1129_31242 NO_ 2.pdf
CRB_282018_1147_31436 NO_ 3.pdf
CRB_282018_1159_31581 NO_ 4.pdf
CRB_282018_1211_31456 NO_ 5.pdf
CRB_282018_1222_31438 NO_ 6.pdf
12 hours ago, Richard Mills said:
In my opinion injector No1 is not delivering enough, but it is marginal. A round of injector cleaner should fix it.
The test results are very detailed, a good report.
On the V6, it's normally injector 6 that overheats and fails.
Thank you, Yes the difficult one to remove, underneath the loom...
No 1 is a fraction out according to the test and certainly a good round Injector cleaner should do the job..Thank you
