Nils Posted December 18, 2006 Share Posted December 18, 2006 Hi My name is Nils, and I live in Norway I own 2 landrovers, one is a 1966 mod. serie IIa, 88" Truck cab with a 2.25 ltr petrol engine, the other one is a 1998 mod. Discovery, with a 300tdi engine. I`m having a small problem with the interior lights in the disco, wich I hope mayby you can help me with: when I open the drivers door, the lights go on, but, when I then open another door, the lights go off..... This does not happen with a combination with the other doors, only with the drivers door. I have tried to cleen the swith, but this did not help. Anybody that has experienced something similiary??? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 18, 2006 Share Posted December 18, 2006 I can only explain the last bit which will be because the drivers door is on one circuit and all the others are on a single circuit together, but I can't help with the problem sorry, maybe some sort of earth fault would be my guess (the door switches work by earthing the wire to the body as you probably know) Quote Link to comment Share on other sites More sharing options...
