Lmack95 Posted November 11, 2018 Share Posted November 11, 2018 Hi all my 90 pickup has had no functioning heaters since I bought it I have limited electrical skills and I am struggling here. No power at fuse box for the blowers when I have checked for continuity at the fuse box and I can get a connection to earth from both sides which I don’t think should be right has anyone else encountered this problem before I go through a cold winter haha thanks in advance. Quote Link to comment Share on other sites More sharing options...
Farmerfred Posted November 15, 2018 Share Posted November 15, 2018 Can you find the connection at the motor?, if so, disconnect the plug and test if the power is coming to the motor, if not then do the same at the switch end. If still no power trace the wiring back to all connections. It may be that you have a dirty corroded connection somewhere so as you inspect each, clean them, it may be that simple. Heater in a Land Rover is for wimps really! As for wiring diagram there should be something on the 'net or try and find a Haynes manual by year of manufacture, the one I have is 1983 to 1995 and covers the 2286cc and 2495cc 110 and 90 diesel models, if that covers yours the ISBN number for the manual is 18859600174, type the number in Google search and it will come up with places you can obtain a copy. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted November 15, 2018 Share Posted November 15, 2018 Do you have the ignition on when testing? Quote Link to comment Share on other sites More sharing options...
Farmerfred Posted November 15, 2018 Share Posted November 15, 2018 Yes but you can test the heater blower motor by connecting it directly to the battery, that way you will know if the motor is okay or not. Quote Link to comment Share on other sites More sharing options...
