ricky25 Posted December 18, 2018 Share Posted December 18, 2018 I have a problem with the central locking on my 2003 (L322) RR Vogue. It all works as it should apart from the driver’s door not unlocking with key fob. When the key is pressed I can hear a “clunk” noise in the door. The driver's door can be opened by inserting the key into the lock. If using the dashboard locking button, all doors lock and unlock apart from the driver's door. I think I can deal with dismantling the door myself but need to know in advance which replacement parts to buy. Your help and advice would be much appreciated please. Quote Link to comment Share on other sites More sharing options...
teabag Posted December 23, 2018 Share Posted December 23, 2018 The drivers door lock is can not only be remotely locked/unlocked but also manual locked/unlocked, therefore without testing to confirm it appears you may have an iffy drivers door lock actuator. I expect the actuator is part of the lock so if you find it’s the actuator that’s faulted the whole lock will require replacing. But it could be something simple, lubrication, detached part...but you’ll have to remove the door card to find out. Quote Link to comment Share on other sites More sharing options...
