RizzleKicks Posted April 6, 2019 Share Posted April 6, 2019 Evening Folks, After having the Clutch , Slave & Master done by the garage last week @ covering approx 300 miles , I went over a speed bump and 20 seconds later no gears , well was stuck in 1st gear managed to drive approx a mile and call the AA. Surprisingly the AA arrived within half an hour, popped the bonnet and identified it as being the Gear Box Selector Rod/ Rods ball joint has come away as the Rods were just hanging loose. He could get his hand so far but was restricted with the engine to pop it back on , he did say if he could have got underneath it would be a simple case of popping it back on. Now my question is what do in need to order or what caused it to dog this ? Is it a simple fix ? Freelander 2004 TD4 Quote Link to comment Share on other sites More sharing options...
Boxbrownie Posted April 7, 2019 Share Posted April 7, 2019 You need to go back to the garage who fitted the clutch, sounds like they didn’t reinstall the linkage correctly. Quote Link to comment Share on other sites More sharing options...
