Peterla Posted January 1, 2007 Share Posted January 1, 2007 I have just pulled down my steering box to fit a new seal kit to it. Unfortunatly I found my selector sharft lower bearings damaged. Not sure how this has occoured but it is probably why my shaft is leaking excessivly. Has anyone attempted to replcae these bearing? A second hand box is very expensive here in Australia. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted January 1, 2007 Share Posted January 1, 2007 I should imagine that if you can get the bits for the steering box, then it's possible to re-build it yourself, dependant on your ability to do it and any special tools required. Are there no companies that will recondition it for you? Might be cheaper than buying a new one. Les. Quote Link to comment Share on other sites More sharing options...
