Henry_b Posted February 9, 2020 Share Posted February 9, 2020 Hiya Gents/ladies. New member here, I can't find an intro section so i thought i'd incorporate an "issue" thread with a "hello" thread lol A few weeks ago my TD5 developed an Idling/misfire/stalling issue, so with the advices from other enthusiasts i replaced the injector harness, this unfortunately didn't fix the issue.. After the harness, she'll sit at idle perfectly fine however if you try and rev it over 3k it seems to drop a cylinder and smoke like a banchee, it'll misfire for a while , but if you let it idle it burns off the oil or diesel and idles happy again... This is pre injector harness. https://youtu.be/O_mNlEb-H8c This is post. https://youtu.be/qU1z_riNU7A the smoke is blue, would failed injector seals cause this issue? I haven't driven or run it for very long so i haven't noticed the oil level rising.. I appreciate any and all help.. Henry.. Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted February 9, 2020 Share Posted February 9, 2020 Is the fuel pump noisy? Normally things to check are the injector seals , the fuel pump and the injector loom. Your you tube links haven't worked. Did you copy the whole address from the top in the address bar? Steve 1 Quote Link to comment Share on other sites More sharing options...
Henry_b Posted February 9, 2020 Author Share Posted February 9, 2020 Hiya.. The Pump has always been noisy, from the day i bought her, it hasn't changed. once it idles for a while it runs ok.. Quote Link to comment Share on other sites More sharing options...
