Deanm1987 Posted March 13, 2020 Share Posted March 13, 2020 Hi I'm new to the freelander scene. Bought a 2004 1.8 k series for the Mrs cheap knowing it needed a head gasket. I've done the gasket and in the process of re fitting the cams. I put the cams back in in what I thought was the right order however then turning the cams to the correct timing position I was unable to move the exhaust cam at all! Now I'm wondering if I've mixed the cams up at some point. So my question is, is there a way to identify which cam is which? I've noticed one has lyd 48 (or 4B) and the other lyd 58 ( or 5B) stamped on them. Any help would be much appreciated thanks. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 13, 2020 Share Posted March 13, 2020 Have you got the factory RAVE manuals? Quote Link to comment Share on other sites More sharing options...
Deanm1987 Posted March 13, 2020 Author Share Posted March 13, 2020 2 hours ago, FridgeFreezer said: Have you got the factory RAVE manuals? No I haven't unfortunately. Could I measure the lobes? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 14, 2020 Share Posted March 14, 2020 The RAVE manuals are online for free, I think there should be links in the technical archive section. Quote Link to comment Share on other sites More sharing options...
