david allberry Posted August 26, 2020 Share Posted August 26, 2020 Morning all My hydraulic brake (works as the piston activates the brakes as the load pushes forward) no longer operates. Possible master cylinder or seals. Anyone done a repair and know where I can source the bits needed? Regards, David Quote Link to comment Share on other sites More sharing options...
neil110 Posted October 2, 2021 Share Posted October 2, 2021 A decent motor factor ought to be able to source yu a master cylinder. From memory it is something like 7/8" If you cannot source a replacement then it is possible to have them sleeved internally to restore them to original, however that is NOT a cheap option Quote Link to comment Share on other sites More sharing options...
