Maborgeneral Posted October 24, 2020 Share Posted October 24, 2020 where is the diagnostic port to reset the srs light , RHD 300 tdi RR Classic Quote Link to comment Share on other sites More sharing options...
Snagger Posted October 25, 2020 Share Posted October 25, 2020 It’s under the passenger seat, I think, though that may be just the ABS unit and plug. The SRC ECU is under the centre console cubby box, so if you remove the centre console, you’ll be able to trace the wiring. The console is removed by lifting away the gear lever gaiters and the flat area matting and pulling off the window switch surround. Undo the two screws near the front of the console and in the cubby box, and remove the screws from the window switch panel. Once the window switch cluster is out of the way, with the car chocked or in gear (both if on a slope), release the hand brake to remove the clip and cotter pin securing the handle to the Bowden cable so that the lever can be raised up for the console to be lifted up. You don’t need to worry about the cigarette lighter wiring if you’re just lifting the console to ding the SRS plug. Quote Link to comment Share on other sites More sharing options...
Maborgeneral Posted October 29, 2020 Author Share Posted October 29, 2020 thanks ,I have found an unused blue plug under to n/s seat I will have to look further towards to centre console . Quote Link to comment Share on other sites More sharing options...
Snagger Posted October 30, 2020 Share Posted October 30, 2020 I think that is for the ABS. Quote Link to comment Share on other sites More sharing options...
Maborgeneral Posted December 9, 2020 Author Share Posted December 9, 2020 found the plug/socket for the SRS under. the dash near the steering column , now just need to find someone with a code reader to reset it , Quote Link to comment Share on other sites More sharing options...
