Steeee Posted January 27, 2021 Share Posted January 27, 2021 Hiya I’m Steve a long time lurker but a friend uses this forum and I keep meaning to post up I own a lovely standard almost mint, original boot floor, arches sills and inner wings disco 1 3.9 v8 I brought the car from a chap that had owned it three times from new and covered 110k it’s only on 127k im currently having a little gearbox issue with the auto box. when you select drive it pulls away fine from cold with no worries until you ease off the throttle and reapply it it won’t shift back up to second Iv ordered fluid and a filter to see if that cures it failing that will get a temporary box and rebuild mine Quote Link to comment Share on other sites More sharing options...
teabag Posted January 27, 2021 Share Posted January 27, 2021 (edited) Hi and WELCOME to the Forum Its not unknown and has been posted a few times in forums that when the gearbox is cold in winter the gearbox is sluggish to change up after D is selected, usually a fluid change clears the issues. Iv never had any issues with my gearbox selection so may not be that common, mines had the fluid changed a couple of times in its life so may or not helped. Being unable to detect the gearbox selection is an good sign as it’s difficult to detect, if you can its usually a sign of wear, of course u know its dropping a ratio or two in kick-down. Take the disco for a gearbox road test before and after the fluid change following the procedures below where possible. For more info download LRs disco workshop manual. Edited January 27, 2021 by teabag 1 Quote Link to comment Share on other sites More sharing options...
Steeee Posted January 27, 2021 Author Share Posted January 27, 2021 Your a star will give it a go this weekend Quote Link to comment Share on other sites More sharing options...
