d-90 Posted January 15, 2007 Share Posted January 15, 2007 Hello, Have a very annoing "clank" coming from my 2002 Defender 90 when I change gears...It has rear detroit locker, front truetrac, had new bushes fitted, but the clank won´t go away. I´ve noticed that if I turn centre diff lock on, the 90 goes smooth and the clank dissapears, when I turn it off, it appears again. Anyone?? Quote Link to comment Share on other sites More sharing options...
GBMUD Posted January 15, 2007 Share Posted January 15, 2007 There is something loose in the transmission at or after the diff-lock. By which I mean that there is too much backlash in the crownwheel/pinions or there is wear in the halfshaft/diff splines or the prop shafts are loose or the U/Js are gone or the gearbox output splines are worn or there is play in the bushes/not done up tight or a combination of these factors. Most likely on this list is bushes IMHO. I have a similar clank which I suspect is the hockey stick bushes on the front axle although I know that there is a lot of free-play in my rear diff.. Chris Quote Link to comment Share on other sites More sharing options...
