Anderzander Posted June 26, 2021 Share Posted June 26, 2021 I’m having the devil of a job bending up my 1/4 brake reservoir pipe. So I’m going to look for some pipe benders that can do decent radius bends. That would be good in this instance would be a flexible pipe. I need 340mm Female 7/16 UNF to Male 7/16 UNF The Girling master cylinders have a machined surface and I believe can be used with banjo or pipe fittings - so something like this should work I think ? https://www.competitionsupplies.com/master-cylinder-inlet-adapter-7-16-unf-to-8mm-push-on Is there any female to push on fittings that seals against a pipe type male fitting for the reservoir end ? Quote Link to comment Share on other sites More sharing options...
Anderzander Posted June 26, 2021 Author Share Posted June 26, 2021 Addendum- I have replaced the reservoir, and I might be able to remove the fitting and replace it with a push fit one … However the fitting on the old reservoir seems bonded in … Quote Link to comment Share on other sites More sharing options...
