norseman Posted July 30, 2021 Share Posted July 30, 2021 (edited) Could any hard-dash Classic owners tell me if their facia fresh air vents both face the same way (ie the passenger side vent on a RHD car is closed when the slider is moved towards the left) The vents will only fit into the facia one way therefore cannot be rotated 180 degrees, so is there a left & right hand part number ? Thanks to all. Edited July 30, 2021 by norseman Quote Link to comment Share on other sites More sharing options...
defender dinky Posted July 31, 2021 Share Posted July 31, 2021 Hi, my n/s slider is closed when moved to the right, o/s closed when pushed to the left, 1988 efi v8, dd Quote Link to comment Share on other sites More sharing options...
norseman Posted July 31, 2021 Author Share Posted July 31, 2021 Many thank for your reply, so the vents must be handed (?) whereas my '87 must have two the same. I'll have to do a part # search Your help is appreciated. Quote Link to comment Share on other sites More sharing options...
defender dinky Posted August 1, 2021 Share Posted August 1, 2021 Just a thought, would it fit if turned upside down, mine are the same shape which ever way you look at them, depending on fitment of course, dd Quote Link to comment Share on other sites More sharing options...
norseman Posted August 21, 2021 Author Share Posted August 21, 2021 On 8/1/2021 at 9:47 AM, defender dinky said: Just a thought, would it fit if turned upside down, mine are the same shape which ever way you look at them, depending on fitment of course, dd Sorry for the late reply, I've been experiencing PC problems. I've tried rotating the vent, but although they initially look the same either way up the moulding is different on bottom edge, which means it doesn't fit into the aperture in the dash properly. Now that I'm back on line it's time for a little more 'digging' Quote Link to comment Share on other sites More sharing options...
defender dinky Posted August 21, 2021 Share Posted August 21, 2021 Worth a try, hope you get sorted Quote Link to comment Share on other sites More sharing options...
norseman Posted August 22, 2021 Author Share Posted August 22, 2021 17 hours ago, defender dinky said: Worth a try, hope you get sorted Thank you. Thinking 'breakers' maybe? Quote Link to comment Share on other sites More sharing options...
