Pino54 Posted January 23, 2022 Share Posted January 23, 2022 Hi, I need some advice, I'm mounting the whole odometer of the td5 on my defender 200td, now I wanted to know in the image the wire of the nr. 12 (wc), should it be connected directly to the plug ypc10175 20 nr.3 (wo)? thank you gauges_diagram.pdf Quote Link to comment Share on other sites More sharing options...
western Posted January 23, 2022 Share Posted January 23, 2022 On Td5white/orange wire is low fuel warning on a 200Tdi low fuel warning light wire is White/grey OnTd5 the speedo internal circuits controls the fuel gauge & low fuel light, you can just connect the 200tdi white/grey direct to the dash low fuel warning light, no need to go through the speedo plug/circuit. Quote Link to comment Share on other sites More sharing options...
Pino54 Posted January 23, 2022 Author Share Posted January 23, 2022 Quindi non c'è bisogno di collegare il filo del contachilometri che esce dal nr. 12 giusto? So there is no need to connect the odometer wire coming out of nr. 12 right? Quote Link to comment Share on other sites More sharing options...
western Posted January 23, 2022 Share Posted January 23, 2022 Pretty sure I did not connect it, have a look & read through the Wibbly Wobbly speedo thread on here, lots of info in there Quote Link to comment Share on other sites More sharing options...
Pino54 Posted January 23, 2022 Author Share Posted January 23, 2022 55 minuti fa, Western ha detto: Abbastanza sicuro di non quello collegato, dai un'occhiata e leggi il thread del tachimetro Wibbly Wobbly qui, molte informazioni lì Ok, I'm waiting for the transducer and I'll let you know, another question if you don't mind, the arrows of the 200 have only one wire or 2 wires, since they only go to one illuminator? Quote Link to comment Share on other sites More sharing options...
Pino54 Posted March 2, 2022 Author Share Posted March 2, 2022 We need a little help, the fuel reserve of the tdi 300 does not turn on, something wrong? Quote Link to comment Share on other sites More sharing options...
western Posted March 2, 2022 Share Posted March 2, 2022 On 1/23/2022 at 1:41 PM, Pino54 said: Ok, I'm waiting for the transducer and I'll let you know, another question if you don't mind, the arrows of the 200 have only one wire or 2 wires, since they only go to one illuminator? On the green indicator arrows 1 wire is for the left ind 1 for the right ind, just connect these to the td5 warning panel plug the wire colour code is the same, thats all I did, the warning light panel had its own earth/ground wires. Quote Link to comment Share on other sites More sharing options...
western Posted March 2, 2022 Share Posted March 2, 2022 23 minutes ago, Pino54 said: We need a little help, the fuel reserve of the tdi 300 does not turn on, something wrong? Some 300tdi vehicles didn't have the low fuel level light connected or fitted at the tank sender unit, If your sender only has 2 wires, the low fuel light is inoperative. Quote Link to comment Share on other sites More sharing options...
Pino54 Posted March 3, 2022 Author Share Posted March 3, 2022 15 hours ago, western said: Alcuni veicoli da 300 tdi non avevano la spia del livello di carburante basso collegata o montata sull'unità trasmettitore del serbatoio, Se il tuo mittente ha solo 2 fili, la spia di basso livello di carburante non è operativa. What can I do to fix it? put back the chit that I am attaching? Quote Link to comment Share on other sites More sharing options...
western Posted March 3, 2022 Share Posted March 3, 2022 Just safely terminate it & secure it to the loom. Quote Link to comment Share on other sites More sharing options...
Pino54 Posted March 3, 2022 Author Share Posted March 3, 2022 Sorry but I do not understand Quote Link to comment Share on other sites More sharing options...
Pino54 Posted March 3, 2022 Author Share Posted March 3, 2022 If you are referring to the gray white wire, it always stays on Quote Link to comment Share on other sites More sharing options...
western Posted March 3, 2022 Share Posted March 3, 2022 Yes, Not sure what you mean by Quote It always stays on Quote Link to comment Share on other sites More sharing options...
Pino54 Posted March 4, 2022 Author Share Posted March 4, 2022 Sorry, the reserve light stays on if I put it in mass, is there a wiring diagram to see how to connect it? Quote Link to comment Share on other sites More sharing options...
western Posted March 4, 2022 Share Posted March 4, 2022 If the tank sender only has a ground on plain black wire & a signal wire for the gauge, you can leave the low fuel light disconnected, it is NOT a fuel reserve light. 200tdi wiring diagram in https://www.google.com/url?sa=t&source=web&rct=j&url=https://forums.lr4x4.com/topic/75135-200tdi-wiring-diagram/&ved=2ahUKEwj186jh96z2AhXNTsAKHWOhB2kQFnoECEAQAQ&usg=AOvVaw1uPM8gSXvI2kRggemxI-rN Quote Link to comment Share on other sites More sharing options...
Pino54 Posted March 4, 2022 Author Share Posted March 4, 2022 So in a nutshell I can't take advantage of the td5 fuel warning light on my 300 tdi right? Quote Link to comment Share on other sites More sharing options...
western Posted March 4, 2022 Share Posted March 4, 2022 Only if you use a tank sender unit that has 3 connections like the earlier 200tdi vehicles, but if your vehicle does not have the low fuel wire at the sender connection then no you will not be able to use it. Quote Link to comment Share on other sites More sharing options...
Pino54 Posted March 4, 2022 Author Share Posted March 4, 2022 Ok, what if I change tank float, and put 3-wire float? Quote Link to comment Share on other sites More sharing options...
Pino54 Posted March 4, 2022 Author Share Posted March 4, 2022 I am looking for floats with 3 wires but I don't see any for defender Quote Link to comment Share on other sites More sharing options...
western Posted March 4, 2022 Share Posted March 4, 2022 You need a 200tdi tank sender with 3 connections Land Rover old part number PRC8463 https://rimmerbros.com/Item--i-PRC8463 A quick Google search gives these results https://www.google.com/search?q=site%3Alr4x4.com+200tdi+fuel+sender+unit&oq=site%3Alr4x4.com+200tdi+fuel+sender+unit+&aqs=chrome..69i57j69i58.16442j0j7&client=ms-android-vf-gb-revc&sourceid=chrome-mobile&ie=UTF-8 Quote Link to comment Share on other sites More sharing options...
Pino54 Posted March 5, 2022 Author Share Posted March 5, 2022 Unità mittente serbatoio carburante 110 dal 1991 al 1998 (OEM) AMR1495 Unità mittente serbatoio carburante 110 Early (OEM) PRC8463 *Disponibile* Unità sensore serbatoio carburante per 110 modelli Defender dal 1983 al 1991 (fino al numero di telaio JA915359) e modelli a benzina dal 1983 al 1986. Questo è in metallo con un tubo di raccolta del carburante, i modelli successivi ne hanno uno in plastica.I don't know what to do and take which one Quote Link to comment Share on other sites More sharing options...
western Posted March 5, 2022 Share Posted March 5, 2022 If you want the low fuel warning light to work use the 3 connection early sender & add a 3rd wire from sender to dash. But if you only have 2 wires at the sender connection you will need the later sender, the vehicle is not wired for the low fuel warning light. Quote Link to comment Share on other sites More sharing options...
Pino54 Posted March 5, 2022 Author Share Posted March 5, 2022 Question: which one has three wires, I always see two. grazie Quote Link to comment Share on other sites More sharing options...
Pino54 Posted March 5, 2022 Author Share Posted March 5, 2022 I have this on the defender Quote Link to comment Share on other sites More sharing options...
western Posted March 5, 2022 Share Posted March 5, 2022 1 hour ago, Pino54 said: Question: which one has three wires, I always see two. grazie The early one has 3 wires, 1 to fuel gauge, 1 to low fuel light & ground to the stud between the 2 spade terminal tubes, there is a post on here that gives info on which wire goes to which terminal, Quote Link to comment Share on other sites More sharing options...
