1960 SII 88" Rear prop shaft
Land1960
Hi.
I need to shorten my SII 88" rear prop shaft — another mistake ! Please don't ask... —, but I cannot find the proper lenght. Here are my measurements :
  • from transmission flange to diff flange : 20" 7/8
  • compressed prop shaft (from flange to flange) : 20 3/4
  • prop shaft extended (from flange to flange) : 22 1/2
Thanks for your help !
Hi and welcome ,
I don't have one to hand to measure but if you email one of the UK suppliers ( I use Britcar ) I'm sure the shut length can be provided . Gywn Lewis may also have some info . I will have an 88 on the 4 post soon so can measure then if you still  need it
Edit to add:
I've just checked the green bible and an 88" rear prop is 554mm/21.8" at mid sliding joint travel - it is the S3 WSM but should be the same for a S2
Steve
Edited by steve b
Thanks for the info.
I"m not sure that I can rely only on the Green Bible since I dont have an original rear prop. It was rebuilt using the same tubes, but I made a (huge) newbee mistake when measuring the necessary lenght (please, just don't ask... its hurts enough already...).
What would be the (average) distance between the 2 tubes when the truck is on level ground ? I guess that would be a good way of measuring the lenght of the prop since you need an "ideal" distance to that the prop can slide back and forth.
Thanks.
Note : I don"t intend to go off-roading like hell (chassis too old), so I guess an approximation is going to be ok. Please state otherwise if I'm wrong.
