Hybrid_From_Hell Posted November 12, 2022 Share Posted November 12, 2022 The Basics Of Differentials The best ever explanation Video of how a Differential works The "A - Z" of differential centres for Land Rovers what they are and Pros & Cons of each A Land Rover Casing is not just a LR casing - there are loads and pros and cons to each ! Upgrading - Making Them Stronger Differential "Pegging" / Pegged Casings - What is it and how does it work ? A short video to explain what happens to an unpegged casing when overloaded There are all sorts of different Pegged Casings - Not all equal ! The differences between a Standard LR 2 pin and a LR 4 Pin Center - and a 'forged Cross Shaft' Land Rover Front Half Shafts and CVs, differences Pros and Cons - and Technical Advice Land Rover 2 pins vs 4 pins vs Forged cross shafts and why a Salisbury is sooo Strong ! All about Crown Wheels & Pinions - Ratios vs Heavy duty Vs Standard Crown Wheels & Pinion Ratios and Options explained Technical Video on 'Standard vs Reverse' Crown Wheel & Pinions The effects of changing your CWP Ratios - A real life example....0-60 was 18 seconds - Now Sub 13 ! Differing types of Land Rover Differentials - Pros & Cons. ARB RD56 / RD003 - Pros & Cons and how it works vs other Lockers ARB RD128 - Pros & Cons and how it works vs other Lockers ARB RD128- Daft 'Pipe over Crown wheel issue' - RD128 Air Pipe Upgrade What is the best Locker I can fit to my Land Rover Nige - and why The KAM 'AIR YES AIR' Locking Differential - Strip and Explanatory Video The KAM 'Quill Type' Locking Differential - Strip and Explanatory Video Short / Long Nose Diffs - Which is what and what are the Differences ? Land Rovers rare 'ENV' Series HD axle and Differential All about Land Rover 4 Pin Differentials - Choices, differences pros and cons - more than you'd think ! TerraFirma / Kam / Allmakes TF450 (Electric) E-Locker What Breaks, why - How you can Upgrade / Fix / Protect + some General Carnage ! ARB RD128 - Failure of Centre Tube Why ??..and what you can do to strengthen and avoid issue. Propshafts UJs and Sliders KILL Differential dead quick - check yours regularly - How and Why ! When you run 37s, you can expect to get big bangs and even bigger bills if you don't play very carefully ... So, you really want to run on 37s do you and not break things ? Short Nose Pegged Casing / 110 Rear Differential Upgrade Making your 110 Rear Differential Much much Stronger - Simple Upgrade Upgrading your Pinion seal with a 'Superflange' - Long & Short Nose Differentials Oils & lubrication Oil is not just oil in 2022 - Might seem boring just watch it ! Link to comment Share on other sites More sharing options...
