MikeD Posted December 5, 2022 Share Posted December 5, 2022 Putting a vehicle back on the road that has had an engine, gearbox and transfer box transplant from a known donor It has been working fine right up until the point where it is due to go back on the road and was giving it a final test before the mot and the gearbox has started grinding when in neutral or park but is weirdly ok in reverse or drive. As in the noise goes away and it moves normally It is quite some time since the donor bits were used but they were working fine before the transplant and have worked ok for just moving around the workshop since the engine was wired up All oils have been changed and the gearbox oil filter was changed so it has been mucked about with but like I said it has been working ok since that Any suggestions? Quote Link to comment Share on other sites More sharing options...
