DiscoHere Posted January 11, 2023 Share Posted January 11, 2023 Hi I recently had to replace the high pressure fuel line from the fuel pump in my 2003 Discovery (TD5 with 190K miles on the clock) Today I have a small leak in the top Radiator hose pipe. I think it is time for me to replace the hoses that are likely to cause problems in the future. Any advice as to what hoses I should replace and which ones do not cause problems. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 11, 2023 Share Posted January 11, 2023 The small bleed-off / vent pipe from the top of the rad goes super-brittle, I've seen folks snap the nipple off the rad and/or snap the nylon pipe - well worth checking/replacing if you can I'd say. 2 Quote Link to comment Share on other sites More sharing options...
