Lazeeladuk Posted June 17, 2023 Share Posted June 17, 2023 I have just replaced the ball joints on my 2003 td5 at the same time I have put on replacement front springs with a 50mm lift All went fine or as fine as can be expected, until I drove it, now when I turn under load the TC goes mad until I straighten up can anyone shine any light on this for me pleaseĀ Quote Link to comment Share on other sites More sharing options...
Pawl12 Posted June 18, 2023 Share Posted June 18, 2023 You've not mentioned changing hubs / ABS sensors at the same time, so I assume you didn't change them (Possible cause of unwanted TC operation). Have you checked the hubs for play ? Grab the top & bottom of the wheel (off the ground) & try to rock it back & forwards. Quote Link to comment Share on other sites More sharing options...
