mad_pete Posted January 31, 2007 Share Posted January 31, 2007 REbuilding a 1994 3.9 V8 hot wire from a rangie to go in 90 with ZF4 auto. What bits should I be changing ? List so far Sump Gasket+ sump plug washer New Rubber type late V8 rocker gaskets Plugs Waterpump gasket, and replace timings gears and change with solid steel options Crank rear main seal Set mains and big end bearings Set Piston rings Piper RP4 camshaft kit complete with genuine lifters, timing chain set & all gaskets to fit £320.00 Core plug set Any other suggestions ? Anything I should watch out for ? Quote Link to comment Share on other sites More sharing options...
