ChrissyG7 Posted October 22 Share Posted October 22 Hi having a problem with my Freelander 2 2.2 td4. Cut out on the mrs whist she was out. Got it towed home. Unclipped the fuel line at the fuel filter ( one that comes from the tank) and there was no fuel in the line. This was the same with the other lines at the fuel filter. first thought was must be the fuel pump. had the fuel pump change and car ran for 2 days then conked out again with similar symptoms but notice this time when I unclipped the pipe from the fuel tank to the filter then to cranked the engine no fuel was flowing to the filter again. not sure where else to look as regardless of the issues I’m not getting fuel from the tank but fitted an new pump from the tank. any help please thanks Chris Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 23 Share Posted October 23 What brand of pump did you fit? Have you checked the wiring / fuse / relay for the fuel pump? Quote Link to comment Share on other sites More sharing options...
