VERY OLD DISCO Posted January 31, 2007 Share Posted January 31, 2007 Been welding today. Will a S2/3 gearbox xmember fit in place of that rusty one? Geoff Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 31, 2007 Share Posted January 31, 2007 Difficult to say from that angle - looks similar. If you're not bothered about rivet-counters then fit a bolt-in one, either MOD Series 2/3 or Disco/RR/Defender flavour. Quote Link to comment Share on other sites More sharing options...
VERY OLD DISCO Posted February 4, 2007 Author Share Posted February 4, 2007 Done it, it fits, Just had to cut a couple of bits off and drill some holes. Geoff Quote Link to comment Share on other sites More sharing options...
tuko Posted February 13, 2007 Share Posted February 13, 2007 Since the frame is bare, why not make the crossmember removable, instead of welding it fast to the frame. Would make life a lot easier if the time came that you had to remove the tranny when the body is on. Todd. Quote Link to comment Share on other sites More sharing options...
VERY OLD DISCO Posted February 13, 2007 Author Share Posted February 13, 2007 Since the frame is bare, why not make the crossmember removable, instead of welding it fast to the frame. Would make life a lot easier if the time came that you had to remove the tranny when the body is on.Todd. Thanks Todd, I welded it on as you can see, the part was available and I usually do the boxes through the top, the hard way. Geoff Quote Link to comment Share on other sites More sharing options...
