Sankey Widetrack Mk3 Parts Thread
I’ve recently come into possession of an expedition trailer built on a Mk3 FV2381 Reynolds Boughton (Sankey) Widetrack chassis.
It needs new brake discs and although there is lots of vague information online about it using Ford brake components- including ‘Scorpio’ discs, I can’t find a definitive source that says whether these are front or rear discs or what model year.
I’ve managed to get the correct pads through matching the Mintex part number MDB1287.
Grateful if anyone has any good information they can post here to help me and others in future.
I’ve already found the army AESP which is available here:
 https://assets.publishing.service.gov.uk/media/5a817566ed915d74e6232608/20160119-FOI2016_00155_Palmer_Annex_A_Final.pdf
Edited by chadler
Measure your disc diameter.
Check the Scorpio disc specs.
Fronts will likely be vented, rears solid.
Fronts will be larger diameter than rears.
Then confirm stud pattern (PCD)
Cheers
Dave 🙃
(I just checked for you...😘)
Product details
  • Brake Disc Rotors: front (ventilated)
  • GT number: 0707GT
  • Diameter: 278mm
  • Max. thickness: max 24mm / min: 22mm
  • Centering hole diameter: 63,60mm
  • Height: 47mm
  • Number of holes: 4
  • OEM Number: 1513979, 4056031, 4070864, 5026785, 6676462
  • For SCORPIO II (GFR, GNR, GGR) SALOON / ESTATE (10.1994-08.1998) 2.9 i 24V (152kW/207HP)
  • Fits SCORPIO II GFR GNR GGR SALOON ESTATE 1994 1995 1996 1997 1998
Brand Ford
Manufacturer: EBC
Dimensions number of holes: 4/253x11mm/height: 34mm
Page Left and Right
Made in the UK
Rear axle application area
Tuning & Styling Part: Yes
Turbo Groove disc version
Registration without registration
Colour coating black
Model Scorpio 1
Manufacturer Part Number: GD280-8
Non-ventilated version
Product Type: Brake Discs
Type GGE
Scope of delivery: 2 pieces
Edited by TD5toV8110
