Simon_CSK Posted May 11 Share Posted May 11 After owning my 2009 sport for nearly 3 years I finally replaced the turbo and got my car running properly at tick over. Engine sounds sweet but before I can test drive it I need to understand why the oil warning light is on. My first thoughts are the pressure switch has failed or the speedo clocks need repaired. Am open to suggestions on this. in an effort to make progress can anyone tell me where the oil pressure sensor is located so that I can put a gauge on it and swap it with another switch. At least if I know the pressure is good I can get it mot'd Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted May 13 Author Share Posted May 13 Found it. Offside front underneath the vacuum pump. 21mm spanner. Quote Link to comment Share on other sites More sharing options...
