Chris Davies Posted May 27 Share Posted May 27 Does anyone know the correct procedure for topping up the oil in a hydraulic puller, I have the draper one and when I came to use it last, I noticed it had leaked a small amount of oil. Thanks Chris Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 27 Share Posted May 27 11 minutes ago, Chris Davies said: Does anyone know the correct procedure for topping up the oil in a hydraulic puller, I have the draper one and when I came to use it last, I noticed it had leaked a small amount of oil. Thanks Chris If it's the one I think it is you just unwind the threaded "T" bar and pour a small amount of oil into the hole then refit "T" bar and your good to go If it starts leaking constantly you can substitute oil for grease Regards Stephen 1 1 Quote Link to comment Share on other sites More sharing options...
Chris Davies Posted May 27 Author Share Posted May 27 Thanks for the reply Stephen, I was hoping it was as easy as that, but no info in the instructions. Quote Link to comment Share on other sites More sharing options...
