ANTOINE Posted 11 hours ago Share Posted 11 hours ago sorry for my english , I am french Hi, I have a MS 1 pack on my 90 , 8 year ago on, this is a Nige parts kit after 8 year first problem (so very good pack, thanks again nigel), my naro band is dead, the ref on is 091-3287, 4 wire (but 2 wire is earth ) I have not the name of manufacture .. where I can found the same ? thanks a lot Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted 10 hours ago Share Posted 10 hours ago Any standard 4-wire lambda will work for this, they are nothing special. Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted 10 hours ago Author Share Posted 10 hours ago 3 minutes ago, Bowie69 said: Any standard 4-wire lambda will work for this, they are nothing special. ok thanks a lot, I must change value on tunerstudio ? or not ? (if i keep a narrow band ) I can put widebande ? or narrow band only ( if I don't change value ) Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted 10 hours ago Author Share Posted 10 hours ago for info, I have to a innovate mtx l near me and I can change the sender, but which wire connected to the ecu yellow ot brown ? and I must change info with tunerstudio ? or not and it will work again than the first time ? thanks a lot Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted 10 hours ago Share Posted 10 hours ago You can change the sensor for a wideband, and then adjust the tunerstudio settings to suit, normally something like 7.5-22, 0-5V or something like that. If you change for standard 4 wire narrow band then you don't need to do anything in tunerstudio. I can't read either of your screen shots, they are very fuzzy, sorry. Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted 10 hours ago Author Share Posted 10 hours ago 23 minutes ago, ANTOINE said: for info, I have to a innovate mtx l near me and I can change the sender, but which wire connected to the ecu yellow ot brown ? and I must change info with tunerstudio ? or not and it will work again than the first time ? thanks a lot Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted 10 hours ago Author Share Posted 10 hours ago (edited) Better ? thanks Edited 10 hours ago by ANTOINE Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted 9 hours ago Share Posted 9 hours ago Yellow would work as wideband. Quote Link to comment Share on other sites More sharing options...
