chris890098 Posted February 22, 2007 Share Posted February 22, 2007 Right lads, if i were to re-build my 200tdi engine where (other than main dealer) can i get genuine LR parts from ? Depending on what needs replacing when i strip it down i may need quite a few bits and would rather replace with good reliable parts than after market stuff. Any contacts/info much appreciated. Cheers Chris Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted February 22, 2007 Share Posted February 22, 2007 You could do worse than http://www.turner-engineering.co.uk/. pretty helpful in my experience. Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted February 22, 2007 Share Posted February 22, 2007 Not sure if they do parts and have not used them myself but this lot might be worth a call. L.E.G.S and they are closer to you than Turners. Have used turners in the past found them to be excellent. Pete. Quote Link to comment Share on other sites More sharing options...
chris890098 Posted February 22, 2007 Author Share Posted February 22, 2007 Not sure if they do parts and have not used them myself but this lot might be worth a call.L.E.G.S and they are closer to you than Turners. Have used turners in the past found them to be excellent. Pete. Thanks very much guys, i didn't realise those two actually sold engine parts i always assumed they just refurbished them. I had a recon box fitted by L.E.G.S, very good box but they did dent my chassis with a spreader jack while removing the gearbox crossmember. Didn't notice for a few months and then i probably had no LEGS to stand on (pardon the pun). Ho hum, i'm putting a galv chassis on it in a few months anyway as part of a ground up re-build. I'll no doubt be on here a lot during the build. Cheers Chris Quote Link to comment Share on other sites More sharing options...
