pinny Posted February 24, 2007 Share Posted February 24, 2007 hello again if i put disco in reverse and hold it in reversing lights work if i let go of stick thay go out is this the switch im told these cant be adjusted n plate 300 is it worth replacing switch thanks chris Quote Link to comment Share on other sites More sharing options...
Andy Posted February 24, 2007 Share Posted February 24, 2007 if your switch cant be adjusted then its a R380 box right? (reverse behind 5th). you can try a new switch but if that doesnt work then give up. as far as i understand it the bit the switch works off wears & you need to strip the box down to change it. Quote Link to comment Share on other sites More sharing options...
pinny Posted February 24, 2007 Author Share Posted February 24, 2007 cheers andy yes its got that box ill replace the switch and see what happens i dont fancy stripping the box cheers chris ps camac tyres are ok Quote Link to comment Share on other sites More sharing options...
pinny Posted March 3, 2007 Author Share Posted March 3, 2007 replaced switch today pain to get at but 9.00 pound later and its working Quote Link to comment Share on other sites More sharing options...
