gelf Posted March 15, 2007 Share Posted March 15, 2007 lost drive to front end of the disco today..... alot of banging when turning then nothing... the front props spins but no drive. im thinking that it may be a CV gone....... i have a new defender one..... part number AEU 2522 or DL 4612. any idea of what a 200 tdi disco needs..... will it be the same as the one i have. just need to know before i pull it to bits at the weekend. cheers graham Quote Link to comment Share on other sites More sharing options...
white90 Posted March 15, 2007 Share Posted March 15, 2007 it will be the off side almost certainly PM me your VIN/REG (original) I'll look it up for you a quick look shows RTC5843 Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted March 15, 2007 Share Posted March 15, 2007 Tony Are you trying to get Ralph the sack? Or is it a compettion to see which mod can help the forum the most????? Quote Link to comment Share on other sites More sharing options...
white90 Posted March 15, 2007 Share Posted March 15, 2007 Graham does yours have the large mushroom head drive members? if so RTC5843 2 piece CV same as RR Classic (some models) Quote Link to comment Share on other sites More sharing options...
gelf Posted March 15, 2007 Author Share Posted March 15, 2007 tony... not sure till its in bits...... got a little plastic cap similar to my defender on the end. Quote Link to comment Share on other sites More sharing options...
white90 Posted March 15, 2007 Share Posted March 15, 2007 then the CV's aren't the 2 piece ones and could be AEU2522/R606665 Quote Link to comment Share on other sites More sharing options...
gelf Posted March 15, 2007 Author Share Posted March 15, 2007 thats what i have already...... spare or the 90. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted March 15, 2007 Share Posted March 15, 2007 then the CV's aren't the 2 piece onesand could be AEU2522/R606665 AEU2522 were only used on defender, pre 32 spline CV's,pre 24 spline halfshafts (on the diff end) 2522's also have the "large" rubber center cap,the type that poke out through alloy wheels. the later 32 spline with the smaller cap are what i think Gelf's referring to. Quote Link to comment Share on other sites More sharing options...
white90 Posted March 15, 2007 Share Posted March 15, 2007 32 spline are very late 200 or 300/TD5 (defender)only Quote Link to comment Share on other sites More sharing options...
white90 Posted March 15, 2007 Share Posted March 15, 2007 R606665 Early R/R & Disco CV joints (RR 1969-1987 (to VIN EA305589) - Disco 1989-1993) - 23 spline inner, 10 spline female outer (no stub axle) AEU1828 Stage one S111 - 23 spline inner 24 spline outer stub AEU2522 County and 200Tdi Defender - to axle #20L48865 1984-1994 - 23 spline inner 24 spline outer stub (same as AEU1828 but a slightly longer stub) And here are the carp ones... The info is a bit confusing for some of the later RR/Disco ones - can anyone clarify - LR may have multiple part numbers for the same CV. RTC6862 300Tdi Defender (1993 - current) - crappy (tiny) 32 spline inner, 24 spline outer stub - from axle #20L48866 RTC5843 Later model S1 Disco (Non ABS - 1993 - ?) and RR (Non ABS - 1987-1989 (VIN EA305590 - JA624755)) RTC6811 Later model S1 Disco (ABS) and RR (ABS - 1987-1989) - with 10 spline outer TDJ000010 - possibly also STC 3051? Range Rover Classic 1992-end ABS Disco 1 - with 24 spline outer (I think). STC3204 P38A Range Rover - don't know splines TDR100790 S2 Disco - don't know splines Quote Link to comment Share on other sites More sharing options...
