chrisoleary Posted April 5, 2007 Share Posted April 5, 2007 My project 110 came with most parts of the power steering apart from a pump and the 2.5 n/a engine is not fitted with a twin pulley on the crank. Any idea on parts and where to find them would be great, then advice on how to fit it all would be even better. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 7, 2007 Share Posted April 7, 2007 I would imagine that the twin pulley off of a TD would go straight on. The same block as the TD, so any brackets etc should just swap straight over. The twin pully is a seperate item from the crankshaft damper, so an new aftermarket one is not as expensive as you might think. PAS pumps from Bearmach are not exchange, and will sting you about £120 if I remember the last time I bought one. Just steering box, pipes, and reservoir apart from that. Les. Quote Link to comment Share on other sites More sharing options...
