tedsmart Posted April 21, 2007 Share Posted April 21, 2007 Hi All. I not sure if this is Australian spec or export spec but my 110 1996 Landrover Defenders lights have a toggle switch and I always thought that the first position was for side lights and the second position was for full lights with full beam on the indicator stalk? But mine go first to full lights and second is the same with the indicator stalk operating full beam! is this a switch problem? the side lights come on with the ignition off when the toggle is switched on! Anyone similar or is it just export spec? Any advise would be good Thanks tedsmart (or not so) Quote Link to comment Share on other sites More sharing options...
rtbarton Posted April 21, 2007 Share Posted April 21, 2007 Do the side lights come on the first position with igniition off as well as on? Does the vehicle have a dim-dip relay? Does the stalk operate dim and dip correctly? Do the side & tail lights operate together? American spec (Series) vehicles switch the front sidelights out when the headlights are switched on. Quote Link to comment Share on other sites More sharing options...
tedsmart Posted April 21, 2007 Author Share Posted April 21, 2007 Do the side lights come on the first position with igniition off as well as on?Does the vehicle have a dim-dip relay? Does the stalk operate dim and dip correctly? Do the side & tail lights operate together? American spec (Series) vehicles switch the front sidelights out when the headlights are switched on. Hi, questios questions! yes the side lights come on in the first position with the ignition off and on. In the second position the full beam comes on with the aid of the indicator stalk. the tail lights and the side lights work together. It does seem strange that the stalk only seems to operate one action with two actions!!!! Quote Link to comment Share on other sites More sharing options...
rtbarton Posted April 21, 2007 Share Posted April 21, 2007 So when you operate the stalk, in one position you get full beam, in the other the headlights go out? Quote Link to comment Share on other sites More sharing options...
Guest dew110CSW Posted April 21, 2007 Share Posted April 21, 2007 Sounds like a wiring issue to me (luca**e wiring so don't trust them too far...) Quote Link to comment Share on other sites More sharing options...
